Molteni
I'm particularly interested in cooling the alternator which can produce up to 60 Amps.
To this end we've recently fitted an engine room fan, to force air to circulate from the large cockpit locker.
Yesterday we finished a sail with a half hour motor with the alternator pushing out around 10 amps, and an IR thermometer showed the alternator casing to be 60 degrees C.
I'd like to install a thermostat which attaches to the alternator casing, and will "trigger" a relay to power the 5amp fan. This needs to be make-on-rise when the temperature of the metal casing reaches, say, 80 degrees C.
The engine room air temperature is not a concern, we just need to protect the alternator from overheat damage under heavy load. The fan is plumbed in (but not yet wired) to draw cooler cockpit locker air in close to the alternator.
Can anyone recommend an appropriate thermostat ?
Thanks in advance
Mike
Thanks in advance
Mike
