geem
That is a very inefficient way of doing things. The cockpit locker will heat up. Once everything is hot you won't have a heat sink. You will only be reducing the temperature of the air over the alternator by a small amount if any.The new system will be using the large cockpit locker as a "heat sink" so air flowing past the alternator will be cooler than before
