russ
if your boat had a mechanical fault and only to find out after the expense of it being lifted out and inspected that the drive had been serviced incorrectly or had a part failure?
I take it this is you ?if your boat had a mechanical fault and only to find out after the expense of it being lifted out and inspected that the drive had been serviced incorrectly or had a part failure?
The problem is proving the fault has been caused by the company you employed , your insurer may help your claim but an expert witness may be called from both sides to battle out the claim .
The last one I was involved in as expert witness went on 4 years , which meant the owner was without his boat for that period . At the 11hour before court the company went into liquidation so the owner got nothing .
Which is it? As Tranona says, there's far too little info to comment sensibly... serviced incorrectly or had a part failure?
I've got the same T shirt .Short story - boats are complex machines that live 80% - 99 % of their time in water - worse seawater. They break and go wrong period. Even with religious maintenance they go wrong. Don't waste your time chasing a few £K looking for who is at fault, you may get to 90% whose fault it is but never see a penny. Expert witness etc will cost loads. Owning a boat is not like owning an aston or ferrari - very different world and and very different rules
Probably cheaper to just sort it and move on (financially and peace of mind ). Boating is character building and can be very expensive. (hopefully not often)
Long story - what goes round comes around, I can lend you the T shirt if you want.
