Paulfireblade
I hope you don't mind me posting here but I thought it might be useful to get advice from the specific area I keep my boat and in particular Shotley if anyone from there reads this.
I enjoy Sailing as much in the Winter as any time, the weather is less favourable but it is much quieter and having bought my first boat this year I want to ensure I don't suffer any damage due to freezing conditions. The boat was lifted out in the Summer and annual maintenance carried out and I will be getting the engine serviced with fresh oil shortly.
Advice when laying up a boat over Winter on the hard seems quite straight forward but leaving it in the water so it can be used throughout the Winter seems quite conflicting with some saying to drain out water tanks fresh & hot and don't even use a kettle due to condensation caused while others say the water the boat sits in acts as a heat sink so temps don't vary much so just leave water tank full (Shotley is a locked Marina for anyone that doesn't know so does lack of water movement over Winter make a difference to that theory or is it not even a valid theory anyway?)
I will be staying on the boat for a few days and sailing at least once a month throughout the Winter but I live a hundred miles away so will not be popping down in between unless there was really bad weather in which case I would make a special trip.
I plan to keep diesel tank fairly full to avoid condensation, leave cushions in a pyramid with cupboard doors/lockers open and some bilge boards lifted to allow air circulation, When staying on it I am lucky enough to have a diesel cabin heating throughout.
I am considering a tubular frost heater for engine bay and perhaps a disk type dehumidifier but then I have known of them to cause fires aboard so I am a little reluctant to use a dehumidifier.
I depressurise the water system before leaving the boat all year round so do I need to drain both fresh and hot tanks as well over winter? What about the holding tank, can that be left with some contents?
Any thoughts please on the many things I may not be aware of as there is a big difference from enjoying Winter sailing and being responsible for a boat in between so any advice appreciated.
Thank you, in advance.
Paul
Paul
