E10 Petrol vs E5 Super - much benefit if it's not sitting around long?
Phil_boat
6 Jul 2025
We've been running our Suzuki 200HP outboard on Super unleaded so far, mainly because getting in to winter and sitting around I believe it's less likely to go off. After sitting full for 3 months over the winter it started first flick and ran beautifully.
We're hopefully going for a bit of a decent trip in a few weeks and will use a couple of tanks. Is there any downside to using E10 normal 95 Petrol if it's not going to be sitting around?
It's a 280L tank so a decent saving with the way fuel prices are going at the moment.
Cheers
Cheers
I'd go E10.
Modern outboards are designed to use it.
If leaving over winter then a dash of fuel stabiliser should be added.
It's a significant cost saving over E5.
Some outboards have an oxygen sensor which means you get better performance from higher octane fuel.
I've not actually noticed a difference though.....
I'd go E10.
Does the fuel stabiliser work well enough to keep it fresh for a couple of months?
I guess I’ll have to give it a go and check it’s just as happy. No idea what it’s been run on for the first 300 hours of its life.
