Sailorsam101
Another lovely hot day today and the bloody boat won't start of course!!!
Started both engines and all well...30 mins later the port engine just clicks as if the battery was flat.
Both batteries on that engine are new and fully charged..i checked. So called out Sea Start.
What we/he found was this....
Put a battery pack to the starter motor direct and earth on the engine and it starts form the key first time...so no mechanical issues with the starter motor of relays etc.
Check voltage to start motor and it's 13v..all good there...try starting and it drops to nothing. Check the batteries when trying to start and no voltage drop there at all!!!
Remove starter cable from battery and add a jump pack direct onto it...engine turns over but does not start...jump leads were not good.
Check battery isolater switch to port engine is working and it is.
Check all connections end to end on the cable and no issues found anywhere.
So where we are no is that there is a fault somewhere in the cable that goes from the battery to the isolater and then onto the starter motor...maybe. But we got it to turn over as said above when using this cable.
Next plan is to get a cable direct from the battery to the start motor and see what happens, Are you still following me?..any ideas?
Anybody recommend any good electrical bods on the hamble please?
Cheers
Cheers
