Actually firing a para rocket?
SC35
13 Jul 2021
Having never fired one of these … do you keep the red cap on?
Instructions don’t show a step to remove that before the bang / flash, but the image in the second diagram suggests it has been removed.
I would really like to practice fire one, but I’m not seeing any legal way to do that.
SC35
13 Jul 2021
The bit in #1 where it says, “unscrew red cap” may contain a clue.🕵️
That is referring to the screw cap at the other end.
I hope you are wearing reinforced boots when you try firing yours :ROFLMAO: 😂
benjenbav
12 Aug 2004
Sorry to cause offence. Only trying to make a light-hearted comment. In fairness your pic doesn’t show the other end.
It would horrify me to fire one of those things. Sporting chance of adding second-degree burns to drowning.
SC35
13 Jul 2021
Okay, to make things clearer.
I can un-screw the cap on the right hand side, which reveals a toggle string that I can pull.
But what about that red cap on the left hand side?
I do think that practicing with these things would help if I did need to use them in anger, heaven forbid.
Plum
6 Jun 2001
UK East Coast
No, you do not remove the red cap on the left end and should you ever need to fire one, point at a slight angle (10 to 15 degrees) to the vertical AWAY from the wind. I know it may not sound right, but definitely downwind/AWAY from the wind, not into the wind.
veshengro
23 Jan 2023
Having fired scores of Parachute Illumination flares for terrain or firing range illumination, one piece of advice I feel that is missing from those instructions in the photo is..Having raised the flare, LOOK/TURN your head away before you pull the trigger cord. 👍
SC35
13 Jul 2021
Thank you for the clarification.
jointventureII
30 Jan 2002
Genoa Italy
We saw a demonstration - I can't remember which cap was unscrewed but the flight of the rocket causes it to swing back into the wind significantly once it nears the top of it's flight, what @Plum says is absolutely correct.
Farmer Piles
6 Oct 2020
Deepest Kernow
I have seen rocket flares set-off - very impressive. Years ago I set-off a hand held flare at the end of my garden as it was out of date and I thought it would be a good exercise. Our garden is well hidden so no chance of causing a false alarm.
It was terrifying. Firstly you are supposed to hit the base on the butt of your hand to ignite it. I had to hit it really hard twice on a big rock before it went off. Then the heat and the light!!! It made arc welding seem like lighting a match. I wouldn't have wanted it too close to a liferaft.
Alicatt
6 Nov 2017
Our local coast guard used to collect out if date flares and use them on a practice / demonstration night, public were never allowed close enough to see details though.
They would fire a rocket from the cliff top to a rock pinnacle and then set up a breeches bouy and rescue the poor souls that were on the pinnacle, you could clime the pinnacle from ground level below the cliff so not at all a hardship.
Many, many flares of all types would be set off that evening, it was done once a year by Wick Coast Guard, I could watch it from my lounge window.
Portofino
10 Apr 2011
Boat- Western Med
Fired pyrotechnics in the military.
Pretty self explanatory as per instructions.Agree with plumb you don’t need to remove the LHS weatherproofing cap .
You naturally turn your head away , kinda look down twisting your neck a 1/4 .Yours eyes will blink with the whoosh .
Just hold at arms L and firmly pull the toggle ( after unscrewing the RHS cap ) .
There’s nothing to be afraid here thousands used by the military inc other pyros .
Yes we get training but imho those instructions are basic and easy to follow for “civvies “.
It’s getting a bit woke these day with millennials ( not this thread ) folks fearing pyros opting for newfangled laser flares and the like .
In certain waters eg Fr , if you base your boat there permanently irrespective of its flag there’s a defined pyro pack you have to carry and keep in date .They even fine you if they find any out of date or threaten to ?
At night in a howler while waiting rescue it’s a pyro ( of one shape or form ) that the rescue services are looking out for .
They might save your life .They are your friends .
Ok you may have sent a msg via a mob or indeed triggered a ERIPB , but not everyone will know that because those sigs are invisible. Your are assuming the rescue services have a modicum of coordination? There WHOLE kits fully functional.
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
What, when the boat is sinking or on fire ?
I’d prefer to know in advance.
Well if you will wait that long... ;) I prefer to 'Be Prepared', as the Scouts say.
I've just had a long dialog with Ocean Signal as their PLB3 instructions are rubbish. They were either written by a committee or by somebody who is so close to the product could not stand back and think, "What do I need to say to somebody who has never used this and might be dead in an hour?"
Perhaps you might find a RYA Sea Survival Course useful as the use and abuse of pyrotechnics is covered in detail.
My use of pyrotechnics was as part of a Mountain Rescue Team, I just wish people were taught how to use them using white ones. Pyrotechnics are something that most people don't understand how to use them correctly.
petem
Cotswolds / Altea
www.fairlineownersclub.com
Reply from Plum is good enough for me.
If it's on fire you'll be seen from miles away without any flares.
What circumstance do you foresee setting off a parachute instead of a smoke?
Having learned from a friend that he's seen someone killed by a parachute flare I don't want anything to do with them.
