50:1 2 stroke in a 4 stroke engine?
canoeman
10 Apr 2012
We have a selection of 2 stroke engines and 1x4 stroke engines.
Apparently someone, who shall be nameless, not me, has attempted to run our 4 stroke on 2 stroke fuel. Not to sure the result but do I have to go to the fad of draining the engine or will reconnecting it to normal fuel be OK?
canoeman
10 Apr 2012
Just run it with 4 stroke fuel, started immediately, at bit smokie but that has cleared. I suspect 4stroke through a 2stroke engine could lead to over heating and damage.
Now off to label the fuel tanks
snowbird30ds
30 Mar 2016
Norfolk broads based, coast when time allows.
What would happen if you ran a two stroke fuel mix into a 4 stroke with no oil in it's tank ?
Two stroke oil in the fuel will only lube the bore in that case, the rest would be knackered very quickly.
It also runs weaker and hotter using 2 stroke in 4 strokes.
Mark-1
22 Sep 2008
Totally different engine designs. 4T engines have valve gear on top, as you know, and the petrol mixture doesn't touch those, they rely on oil pumped from the sump. Also the big ends etc. In a 2T engine the mixture goes through the crank covering the con rod ends and main bearings in oil via the mixture. In a 4T engine the oil for that comes from the sump while the petrol goes straight into the cylinder with out circulating through the crank.
ducked
6 Oct 2024
Tainan, Taiwan
Some people run 2T oil as an Upper Cylinder Lubricant in 4-strpke engines.Has to be a low percentage (in the 500's to 1 range typically IIRC) otherwise if theres a catalyst its life will be shortened. I suppose maybe good for diesels on lowsulphur fuel. MPG improvements are claimed though I find it very hard to believe there is evidence for that.
2-cycle oil as a fuel add in 4-cycle engine
Chiara’s slave
14 Apr 2022
Western Solent
Any fuel saved is probably as a result of slightly increased viscosity, and therefore less fuel passing through the jets/injection. Running lean is not a good thing. What you might save in fuel is offset by the increased wear.
Snowgoose-1
2 Jun 2015
At one time, It was all the rage to use an upper cylinder lubricant to reduce start wear . You don't hear so much now. Perhaps high tec synthetic oil overcomes this problem ?
When I had a boat with a Volvo 2000 series engine, it required an extra splash of diesel instead of glow plugs at startup. I always felt that the bores got that extra bit extra lube when the engine was cold.
Refueler
13 Sep 2008
Far away from hooray henrys
Bob's worth of 2T petrol and a shot of Redex please !! Brings back memories of my Lambretta days ..
The gob' of diesel to start your V 2000 .. the diesel basically created a seal when engine cold ... plus acted like the Cold Start on a truck - where instead of heat - the truck CS was an over-ride on the fuel governor - allowing a larger amount of diesel to be injected ... its why later trucks had the CS button out of easy reach of driver ... to stop them using it to get up steep hills !! (I grew up with Bedford TK's .. TD's ... Ford D series .. Leylands etc).
Beneteau381
19 Nov 2019
I
I remember the old engines as well, your anecdote doesn’t chime with what I remember! Most had a coil in the inlet manifold which had diesel dribbled on them to produce vapour or even flames!
