28.5mm to 32mm hose connector
MikeBz
22 Aug 2005
East Anglia
I need to join a 28.5mm (or 1+1/8”) ID hose to a 32mm (1+1/4”) ID hose on the raw water intake side of an engine. The only product I can find is this: Stepped Hose Adaptor (13mm to 38mm). I asked ASAP and that was their recommendation, so it ought to be good enough. It just seems a bit hard to spend £20 on a bit of plastic and cut off/discard most of it. Trudesign do a range of unequal connectors but nothing in between 25 and 32mm. With a bit of bronze bar or tube of the right diameter I could get one turned up, but sourcing that in a very small quantity doesn’t look easy. Aluminium would be easy but unanodised I suspect it wouldn’t last long. Any suggestions before I just buy that stepped plastic connector?
Have a look here.
35mm > 32mm Silicone Reducer Hose Coupler Intercooler Tube Blue
Well… I was only thinking of an internal connector, but a silicone reducer would go directly onto the water pump (28.5mm) and I could then use a quality 32mm internal connector (Trudesign) at the other end. The silicone reducers also come in 45 and 90 deg bends, one of which (prob 90deg) would be a neat solution. Thanks all!
2 short pieces of copper pipe set between a reducer
I do not know what copper life is though.
A plumber will have the copper offcuts & a merchant will have the reducer.
then just solder the 3 bits together. Plumber will do it for you.
Alternatively use Osma plastic pipe & compression fitting between.
Any reducer will further restrict the flow of water which might be important in relation to the engines cooling.
So I’m decided: 1” BSP skin fitting/ball valve, 32mm hosetail, 32mm inlet & outlet on the strainer, raw water pump has ~28.5mm inlet (which is part of the pump casting and cannot be changed). So with a tapered silicon hose on the pump, 28.5mm at the pump end, 32mm at the other end connected to the pipe from the strainer by a straight connector, the smallest diameter is the inlet to the pump itself. Thanks to @Alex_Blackwood for putting me on that route!
28mm, 32mm, and 2" piping is common in swimming pools and there are plenty of conversion connectors available for them.
I have 28mm Intex valves on the pool but the piping to the solar panels are 32mm and go through a stepped reducer between one and the other.
Pleased to be of help 🤞it works.
