2 stroke oil mix
nemodreams
4 May 2002
Bristol UK
I always think of mix being 1:50 - rather than 50:1 - ie oil to fuel, rather than fuel to oil - after all, I add oil to fuel generally, not the other way around !
ie - 1:50 = 2 :100 hence 20 to the 1000 ( ltr ) ( just seems easier that way )
It gets confusing when keeping mix at 1:50 which I generally use in my Suzuki tender - but then altering it to 1:20 for the seagull if I need to run it. 1:20 mix is 5:100 - 50 to the ltr. So if I need to run the seagull I know I add 30 to each ltr suzuki mix :ambivalence:
Geoff
Seajet
23 Sep 2010
West Sussex / Hants
Our garden centre machinery dept has really handy mixing bottles, with which one can fill up to a level with petrol, then add amounts of 2-stroke oil to get mixture ratios marked on the side.
Although only a litre or so at a time these things are a godsend, before that I'd used small medicinal bottles I'd stumbled across which give the right mixture for 1 bottle to 5 litres of petrol = 100:1, 2 bottles = 50:1.
I still use those bottles, but at home for the garden machinery or anyone else who hasn't got those old bottles - sorry, labels rubbed off years ago - the mixture measuring things are great; obviously one wants to mix and prepare any fuel fuel before setting off or it might be a right pain.
I have a rule that any cans of raw petrol get the 2-stroke mixture instantly added, and must not be stowed in the fuel locker unless.
Hopefully this might save much anguish later.
Spyro
18 Jan 2003
Clyde
That's not going to help much if your have a 30l tank and you need to refill it and there's some in it. You need to work out how the sums work.
100ml-to every 5 litres (5000ml) is a good start.
Bav32
26 Dec 2009
I use a "miniture" gordons gin bottle as the measure. It holds exactly 50 ml. so one shot of this does 100 : 1 mix in 5 litres of petrol.
simple arithmetic for different mixes or volumes.
Really handy on long trips / holidays as you can carry a shot rather than the big bottle / measure, and buy replacement petrol for the dinghy trips if you run out.
* Other spirit bottles are available as they say.
prv
29 Nov 2009
Southampton
I do very similar, except I bought ten 100ml plastic bottles (50:1 in a 5l can) for a couple of quid from eBay. Decanted a litre bottle of oil into them and I'm set for the next few years at current consumption rate :)
VicS
13 Jul 2002
This 100 cm³ conical measure is what I use for oil measuring at home.
There is a larger one ( 200cm³ ) on the boat
duncan99210
29 Jul 2009
Winter in Falmouth, summer on board Rampage.
djbyrne.wordpress.com
I use an old spice jar with a bit of tape at the 50cc point. Because it has a wide neck, it's easy to fill without dribbling oil. Before that, I had a 100cc bottle from Morris Oils marked at the half full point but that had a narrow neck and I was forever spilling oil as I filled it. Then again, even spending most of the summer on the hook, we've still only used about 25 litres of fuel so it's not like it a major problem.....
aquaplane
16 Sep 2006
West Yorkshire
www.utilitywarehouse.co.uk
My engine manual says to use 100:1 for emissions reasons, but from previous discussions the engine will probably last longer if I use 50:1.
I usually split the difference, sometimes more green, sometimes more engine friendly, so using a measuring cylinder is a bit OTT when aiming for somewhere between 50 and 100ml for a 5L petrol can, but I use one anyway.
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
The ancient Sachs Dolmar chainsaw I have just refurbished (it has a cam, points and a condenser!) has 25:1 stamped on the fuel tank cap. It should last forever although it kills the trees before I have a chance to cut them down. :(
Richard
VicS
13 Jul 2002
You dont say what engine
some were said to run on 100:1 but later changed to 50:1 ( Johnsons and evinrudes)
50:1 is usually specified for commercial or heavy use even when 100:1 for leisure use.
If it runs happily on 50:1 use it!
