2 stroke oil mix
I always think of mix being 1:50 - rather than 50:1 - ie oil to fuel, rather than fuel to oil - after all, I add oil to fuel generally, not the other way around !
ie - 1:50 = 2 :100 hence 20 to the 1000 ( ltr ) ( just seems easier that way )
It gets confusing when keeping mix at 1:50 which I generally use in my Suzuki tender - but then altering it to 1:20 for the seagull if I need to run it. 1:20 mix is 5:100 - 50 to the ltr. So if I need to run the seagull I know I add 30 to each ltr suzuki mix :ambivalence:
Geoff
Our garden centre machinery dept has really handy mixing bottles, with which one can fill up to a level with petrol, then add amounts of 2-stroke oil to get mixture ratios marked on the side.
Although only a litre or so at a time these things are a godsend, before that I'd used small medicinal bottles I'd stumbled across which give the right mixture for 1 bottle to 5 litres of petrol = 100:1, 2 bottles = 50:1.
I still use those bottles, but at home for the garden machinery or anyone else who hasn't got those old bottles - sorry, labels rubbed off years ago - the mixture measuring things are great; obviously one wants to mix and prepare any fuel fuel before setting off or it might be a right pain.
I have a rule that any cans of raw petrol get the 2-stroke mixture instantly added, and must not be stowed in the fuel locker unless.
Hopefully this might save much anguish later.
That's not going to help much if your have a 30l tank and you need to refill it and there's some in it. You need to work out how the sums work.
100ml-to every 5 litres (5000ml) is a good start.
I use a "miniture" gordons gin bottle as the measure. It holds exactly 50 ml. so one shot of this does 100 : 1 mix in 5 litres of petrol.
simple arithmetic for different mixes or volumes.
Really handy on long trips / holidays as you can carry a shot rather than the big bottle / measure, and buy replacement petrol for the dinghy trips if you run out.
* Other spirit bottles are available as they say.
I do very similar, except I bought ten 100ml plastic bottles (50:1 in a 5l can) for a couple of quid from eBay. Decanted a litre bottle of oil into them and I'm set for the next few years at current consumption rate :)
This 100 cm³ conical measure is what I use for oil measuring at home.
There is a larger one ( 200cm³ ) on the boat
I use an old spice jar with a bit of tape at the 50cc point. Because it has a wide neck, it's easy to fill without dribbling oil. Before that, I had a 100cc bottle from Morris Oils marked at the half full point but that had a narrow neck and I was forever spilling oil as I filled it. Then again, even spending most of the summer on the hook, we've still only used about 25 litres of fuel so it's not like it a major problem.....
My engine manual says to use 100:1 for emissions reasons, but from previous discussions the engine will probably last longer if I use 50:1.
I usually split the difference, sometimes more green, sometimes more engine friendly, so using a measuring cylinder is a bit OTT when aiming for somewhere between 50 and 100ml for a 5L petrol can, but I use one anyway.
The ancient Sachs Dolmar chainsaw I have just refurbished (it has a cam, points and a condenser!) has 25:1 stamped on the fuel tank cap. It should last forever although it kills the trees before I have a chance to cut them down. :(
Richard
You dont say what engine
some were said to run on 100:1 but later changed to 50:1 ( Johnsons and evinrudes)
50:1 is usually specified for commercial or heavy use even when 100:1 for leisure use.
If it runs happily on 50:1 use it!
