ste7ve
I have a Nimbus motorboat with a bank of 3 x 80Ah service batteries.
I replaced them last week and also also installed a Victron app on my phone which displays the battery condition, via bluetooth from the Victron battery monitor. This makes it easy to see the current and voltage when going around the boat.
At anchor yesterday (first time on this boat), I found that even with the main service battery switch on OFF I had a continuous current drain of 17 to 20 amp, with corresponding drop in voltage. This may partly explain why I had to replace the old batteries, apart from them never having been topped up, and why the shorepower charger always seemed to be on.
There are clearly things which are wired not through the main battery switch, eg. feeds to two auto bilge pumps, maybe also the radio. I could not find anything running at all that would be taking this level of power, which was up to 250 watts. Something should be getting hot because of this rogue current flow...!
Has anyone some thoughts on what may be causing this situation?
The only thing I wondered is if the Mastervolt charger could somehow have a fault causing the current loss, because clearly it is connected to the battery bank.
I also have a Mastervolt Battery Mate, which controls the charging from the alternator across my 3 battery banks, engine, service and heavy gear (thruster & windlass).
