collinsp
Hi Guys,
I am having an issue with the 12V LED lights in the cabin when I run the water pump they flicker. There is no issue with battery voltage and the pump is wired directly into the electrical panel on/off switch and also has a whale pressure switch located near the pump. I have checked the voltage to the lights when the pump runs and there is no drop in voltage. I'm wondering if the pump is causing some sort of frequency when operating that is effecting the cabin lights (sure I read that somewhere in the past)?
Any thoughts and suggestions would be much appreciated.
Paul
Paul
