Stud and joist marksAny ideas what this shape measures or indicates?
Brb, just off to ask Mrs Google what a stud and joist might be and which anchor these mysterious things might use?Stud and joist marks
Expansion anchor bolts, Rawlplug make plastic versions, but for security steel anchors are better (I think the plastic ones might float).Brb, just off to ask Mrs Google what a stud and joist might be and which anchor these mysterious things might use?
But you have to be very careful about wear and tear...my one is a millimeter or two outSometimes also see brick/block courses marked on tape measures.
More interesting (to me) is I recently found out why the end is loose! The movement of the end clip is the same as its width, meaning if you push it against something the measurements are accurate but if you hook it over something the measurements are still accurate.
I imagine you’re right, but it was a revelation to find out they are loose on purposeBut you have to be very careful about wear and tear...my one is a millimeter or two out
Our mooring master has very "special" type of tape.I sometimes wonder if some forumites should be allowed out with a tape measure.
The above comments confirm my suspicions.![]()
Quite often the hose isn't long enough, as I know from experience plus the hose rubbing all overvthe bodywork isn't goodthese marks on everyday items are often missed by people ...
Another is the side of car that fuel input is ... look on dash at fuel gauge - usually an ARROW is shown - that indicates which side filler is. Clever these ba*****s !!
Tape measure markings
Forgot Which Side the Gas Tank Is On? There’s a Shockingly Easy Way to Know
With ref to Petrol filler - I really detest idiots who insist on turning car round to get filler same side as pump ... The pump hose is long enough to go other side of car ... just put the bl***y car a touch closer ... where is should be anyway - so others can use the other pump !!!
