Neeves
A blow torch.What would one use for Dynema rigging?
Always have drill, grinder and multi tool which all share same battery on board with 2 large cap battery’s and spare charger always stays on board, can then deal with most stuffBut what if you are in trouble on the boat. Not in the workshop. Do you take a stackof batteries with you every time you go? I bet owners rarely even take one.
OK on a steel deck but useless on a GRP or teak one as one would just push the wire through the GRP.
It is a bit like people saying they would cut anchor rodes etc. with an axe. Unless they have something solid to chop against it is a useless tool.
I bought my bolt croppers after I tried them in the shop on rigging wire. They cut it with ease.So you need to hget better croppers. The cutters are used for nothing else so the blades are sharp & I have adjusted them to close right up. I keep them in holders on the back of one of the engine panels where the heat of the engine keeps them dry when the boat is in use. The panel is the one to the heads so when s..t happens- in a panic- one can use the heads then grab the cutters & get chopping. Well that is what I tell myself anyway. They have a cord fitted to one handle which goes around my wrist. Then when they go over the side they take me with them & I drown quicker due to the weight.The point was to illustrate my bit about Bolt Croppers being generally useless.
I carry threeBut what if you are in trouble on the boat. Not in the workshop. Do you take a stackof batteries with you every time you go? I bet owners rarely even take one.
Should have hard wired them in to the batteryIf its 12 - 15v ... you can always create a lead to power from on-board batterys. I did that with a drill - till someone borrowed and it went missing !!
Should have hard wired them in to the battery![]()
I don’t want to get into top trumps batteries but we carry four. Partly because I’ve got Makita drill, multi tool, jig saw, angle grinder, router and 1/2 drive rattle gun that all take the same batteries. They’re all usually fully charged.I carry three
It's like Pokémon, you've got to collect them allI don’t want to get into top trumps batteries but we carry four. Partly because I’ve got Makita drill, multi tool, jig saw, angle grinder, router and 1/2 drive rattle gun that all take the same batteries. They’re all usually fully charged.
When cutting rigging wire with a hydraulic tool the action is infact a shearing action unlike a hacksaw or angle grinder. ...
They all cut by shearing. Hacksaw and grinder just have smaller cutter faces shearing away metal.
There is a difference between a shearing action ans a cutting action as used by a hacksaw and grinder. ...
But surely a hacksaw does work by shearing.There is a difference between a shearing action ans a cutting action as used by a hacksaw and grinder.
A shear is exceeding the shear strength of the material an does not remove any material at the cutting point.
A hacksaw nd grinder is removing material by a cutting action by removing small pieces of material at the cutting point.
With both grinding and sawing you are creating swarf which is created by the cutting action where as a shearing action does not create and swarf
This is the shearing process
This link explains the difference more
Sawing vs. Shearing – Metal Cutting Methods 101
