seaesta2
I have a 34 foot Alberg 34 displacement yacht. 6.5ton. Underwater it is a bit like
a folkboat. A new Yanmar 3GMD is installed under the cockpit and main companionway conventionally Using a flexible plastic coupling to a 2.6 to 1 Yanmar Box. Shaft and gearbox are in line. The shaft is 1inch and about 3ft long to a 3 blade 16.25 by 9 inch pitch propeller.(Prop has been mechanically resized from 17 by 12). When we got the boat it had a resonance at about 1300RPM which was easily missed. On removing the propeller to have it resized due to fitting a 3GMD
reconditioned engine it was found that the propeller had been originally
machined for a 1.125inch shaft and a nylon sleeve had been fitted.
A 316 stainless sleeve was fitted but this has now caused worse
resonances. We get a resonance from about 1000 to 2000 RPM. There is a very small gap and then another resonance takes over from 2000 to 2500. So we are
restricted to going at either 2knots or 6knots because it is difficult to avoid the resonances which cause the shaft system to ring.
HEELP! Is there anything that can be done about these resonances without
replacing the prop?
replacing the prop?
