Yamaha 2a 2hp outboard starts but dies
Shuggy
10 Mar 2006
Argyll
No-one has mentioned compression. My checklist would be as follows, most of which you have done:
Check fuel is clean
Check fuel filter is clean
Check that fuel is getting to carb
Pressure test the fuel line into the carb and check that the needle valve is not leaking
Check for spark
Stick a bore scope into the cylinder and look for bore score
Check compression
Rebuild the carb and make sure the metering diaphragm has the correct clearance
Check that the impulse feed is working
If everything else checks out then bung a Chinese carb in there
If all of that fails then all hope is lost!
obmij
30 Nov 2005
Here's a simple solution.
Take it to an outboard mechanic.
You think the carb looks clean. Has it been ultrasonically cleaned?
How many outboards do you service / repair a day?
Sixty quid and I reckon you'll have a functioning o/b :)
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
I have to get the choke off very quickly, within the first 2-3 seconds after starting. It won't start without the choke unless already warmed up.
Is this true of all 2s?
or is there a jet blocked somewhere?
Runs fine once going.
