Yacht aground at Haulover inlet
Bathdave
4 Apr 2012
jersey, CI
My instinct wold be have been trying try and tow off stern first on the basis you would be pulling back towards deeper water earlier ...but would that have run the risk of snapping the rudder ?
penfold
25 Aug 2003
On the Clyde
A long scope tow on the spinnaker halliard might have been more productive; in a similar self-inflicted grounding we got out by sending fit stupid people up the mast to stand on the spreaders.
NormanS
10 Nov 2008
Some years ago we got involved with something similar at Coll, when a big Dutch steel ketch landed on a rock at the entrance to Loch Eatharna. At the time, we had a 60' converted fishing boat, so had some power. We towed from the bow, but got a wee fishing boat to help to heel the ketch over by pulling on an extended halyard from the masthead. When the ketch came off, and suddenly came upright, fortunately the line from the masthead parted, or the wee fishing boat might have been catapulted into orbit. ?
davidej
17 Nov 2004
West Mersea. north Essex
There is always a tow boat around in USA waters -at a price!
We were ashore when our yacht dragged its anchor off Key West during a sudden squall. It was a lift keeler and ended up on the beach - lucky, if we had anchored elsewhere it could have ended up on rocks.
A boat like that rocked up and $400 and about 5 mins later , we were off.
Resolution
16 Feb 2006
Big warning to anyone using a halyard tow to heel the boat over. Do first attach a mooring line or similar to your halyard before handing an end to the tow boat. In my 13 metre deep keel yacht we once got embarrassingly stuck on the mud at Keyhaven. Walked the crew out on the boom, heeled over a bit, still stuck. One of the ferry boats came along side , took the end of the main halyard to his stern cleat and pulled us over to 60 or 70 degrees. With a bit of motor we slid off into deeper water. The keel did its proper job and brought us upright. Even on full extension the main halyard was just too short and we lifted the ferry stern clear out of the water. I was terrified the mast would collapse. Only by frantic ballast out on the boom did we get enough slack to unclip the halyard. Moral : use an extension line and have a knife handy!
Oh!, and stay out of Keyhaven if you have a deep keel.
  • Wow
Reactions: dom
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
What's that boat even doing there in the first place, because isn't there a bridge just inside the inlet that the mast wouldn't fit under even if there was enough water depth in the channel?
burgundyben
28 Nov 2002
Niton Radio
Erk! The wrong kind of excitement.
Keyhqven has lots of depth, but the deep water us very narrow, barely stray a boats length and you're in trouble.
pelicanpete
1 Jul 2003
Well...the incident happened at Boca Raton inlet, not Haulover. Haulover is further south in N. Miami.
And, to Angus; there is no fixed bridge problem so he was fine. All the bridges on the ICW (Intracoastal Waterway) are lifting Bascule bridges permitting sail boats and large motor boats to pass.
michael_w
8 Oct 2005
65' air draft limit on the ICW. A lot of the opening bridges are being replaced with fixed ones. If cruising the USA membership of one of the towing companies, Tow boat US and the like is cheap insurance. They often have marina discounts too.
