Keith 66
If you are contemplating cedar strip It really isnt worth machining the strips yourself, the wastage in sawdust will be huge, You are better off buying the strips in ready machined in either cove & bead or speed strip which due to its tongue & groove edges goes together more fairly. It is easier than glued clinker & will be marginally lighter. Glued clinker is a good method but it isnt worth using unless you use the very best quality plywood & that isnt cheap.
