Stemar
Jazzcat has a grid between the hulls aft. It used to have a stainless steel frame supporting sapele slats, but the frame is damaged, so I'm replacing it with beams made from what I believe to be Brazilian mahogany salvaged from a replaced front door frame. What treatment would you give the whole thing? I'm thinking of treating the individual pieces before assembly as it'll just be screwed together, not glued, and will get rained on, but have little exposure to seawater.
Burgess Hydrosol comes up often - a couple of coats a few minutes apart. Sounds great, but is it too good to be true?
