Sy-Revolution
Would I wire them in series in pairs, just as you would 12v batteries to make 24v?
I guess I know the answer but need reassurance!
C.
C.
C.
Depends on which type os panels you have. Theoretically yes. Two nominal 12 volts panels will produce 24 volts.
If you Google solar panels will will find that they are produced in 12, 24 and 36 volt configurations. so if you have a 24 volt system, buy 24 volt panels.
If you have already got the panels, 12 x 10 amp panels when put in series (x2) will produce 24 volts at 10 amps
I think you will find that 24 volts panels also are on offer because they are used in PV installation on houses, but the recent government debacle over pricing means that some are being dumped because of a change in demand.
I bought a single 12 volt 80 watt panel last year on Ebay - it works very well!
A nominal 12 volt panel has - for example the Kyocera KD135GX which is very popular for marine installation - has a max voltage of 17.7 volts and a max current of 7.63. To charge a 12 volt battery efficiently - a nominal number in itself - you need about 14.4 volts.
If you are using a basic PWM controller it will output the proper voltage for charging and waste the excess as heat. A MPPT controller will convert the 7.63 amps @17.7 volts to a higher amperage at the proper (14.4) voltage.
C.
A little puzzled.
I understand, I think, the principle of MPPT regulators but surely a PWM regulator is a switching regulator. The output is controlled by varying the percentage of the "ON" time not by dumping the excess energy as heat ?
It's not like the shunt type regulators used for wind turbines in which the excess power is diverted to a shunt and dissipated as heat ?
Not an expert but I would have thought that if the panel is still producing volts when the regulator has switched off feed to the battery, those volts must go somewhere and therefore be dissipated as heat?
The volts dont "go" anywhereNot an expert but I would have thought that if the panel is still producing volts when the regulator has switched off feed to the battery, those volts must go somewhere and therefore be dissipated as heat?
Don't know much about this but puzzled by the replies so far. My "12v" solar panel actually delivers anywhere between 18 and 21v depending on the light. It's the "charge controller" (which incorporates the regulator) that converts it to 12v. So does the solar panel itself matter, couldn't you just use a charge controller set to output 24v? And might rigging two solar panels in series just lead to trouble?
When you switch a torch off the battery volts don't go anywhere.
You only get heat or power produced when a current flows Ie when you switch the torch on and the filament in the bulb becomes white hot.
When no current flows no heat is produced!
In dim light the MPPT controller can actually raise the voltage of a meagre amount from a panel to produce enough voltage to charge a battery albeit at small current.
Very few MPPT regulators will do this.
