SiteSurfer
To the OP, I missed a bit off my reply - you asked about extending ducting and lagging.
Ducting comes in many sizes and without knowing I wouldn't want to guess how big it is, I'd reason that anything between 60-80mm sounds reasonable. That is available on places like eBay and any stockist of any warm air heater (ducting is ducting), the Webasto style stuff is aluminium outer with a what feels like card sandwich inner. Lagging is also freely available and is normally stocked by the same people and in sizes to complement the duct.
To extend your ducting should be an easy task, you can purchase a Y piece that allows you to divert some of the air flow from the main duct, and route that around the cabin and place outlets where you need them. Naturally the more outlets you have divides the output of the heater. If you want to be clever you could have smaller ducting branching off larger ducting at the closest point to the heater which can help with balancing the air flow.
I'm a great believer in using what you have - if what you have is functioning. I don't see any logic in adding more electric heaters or resorting to buying more clothes when a bit of investigation and a really cheap fix could reduce the problem with the already functioning heater! I'm staggered that you have had so little input on the actual problem given the massive expertise on this forum.
