Pinnacle
Mike
I can't believe you have been brave/stupid enough to post those pictures in a thread that you know jfm will look as ( as he indeed has! ) given the colour of the teak!
Mike
my lewmar has a short tough spring about 1 inch long, 1 1/2 wide.
It pops the whole unit up when the top nut is slightly undone allowing free fall/winch up without having to turn the motor/gears.
There is also a small brass square pin (1/4 inch square x 3/4 ) that acts as a ratchet to stop it going back in when in manual recovery mode, ticks like a Swiss watch when correctly serviced.
Slackening the nut releases the cone clutch (clearly visible in Hurricane's pics) , so the gypsy becomes free of the drive shaft while the capstan remains splined to the drive shaft. But the question we're trying to fathom is how do you then manually turn the gypsy with a crank handle to haul in the chain manually?
I know the process may be different but I've just checked the manual for the Lofrans winch fitted to my boat. To loosen the gypsy, you turn the lock nut with the winch handle anti clockwise and, obviously, to tighten it again, you turn the lock nut clockwise. If you need to raise the anchor chain manually you have to turn the lock nut clockwise beyond the position at which the gypsy is tight and overcome what is called a 'spring mechanism'. After you've done that, you can use the winch handle to turn the gypsy and manually retrieve the chain. Not sure where the spring mechanism is or exactly how it works but I guess it's in the gear casing attached to the electric motor. I have to say that I have never tried this on my boat but the manual says that you are then manually winding at a 1:1 ratio so when retrieving the chain, in the words of the manual 'the stress will be hard'Slackening the nut releases the cone clutch (clearly visible in Hurricane's pics) , so the gypsy becomes free of the drive shaft while the capstan remains splined to the drive shaft. But the question we're trying to fathom is how do you then manually turn the gypsy with a crank handle to haul in the chain manually?
I think you de- clutch with a anti clockwise turn and the chain runs free and a turn to clockwise will allow the speed to be controlled and even stopped. My understanding is that a further turn(s) starts the hauling up.
No?
Gotya! Sorry I simply thought that what it did - having dropped the anchor once by de-clutching the gear. Hauled in by motor as could see little point in manually winding the cable.......
I must admit I'm surprised. You would think that a method for manually winding the winch in an emergency would be a basic design feature but as I say, I haven't tried mine yet so I don't know how well it works. Having said this, I suspect that manually winding in the chain on anything but a small boat would be physically very demanding and possibly beyond the capability of many skippers/crew. I don't know whether there is such a thing as a long arm winch handle which could provide more leverage for this purpose?Seems that the Lofrans system is better than the Lewmar one in this case, Mike.
The Lewmar definately just tightens when turned clockwise. If you see my pics, you can see that it isnt intended to do anything else.
You lot are really getting your knickers in a twist over a very simple device.
I will copy the instructions in the Sunseeker manual together with the picture illustrations as soon as I return back tothe UK.
Then I think you will give a collective AHHHHHHH.
That makes sense to me Deleted User. I think I said above that the trick gadget has to be in the gearbox. But my knickers are pretty twisted so I'll be delighted to hear Doug's explanation and AHHHH awayI know the process may be different but I've just checked the manual for the Lofrans winch fitted to my boat. To loosen the gypsy, you turn the lock nut with the winch handle anti clockwise and, obviously, to tighten it again, you turn the lock nut clockwise. If you need to raise the anchor chain manually you have to turn the lock nut clockwise beyond the position at which the gypsy is tight and overcome what is called a 'spring mechanism'. After you've done that, you can use the winch handle to turn the gypsy and manually retrieve the chain. Not sure where the spring mechanism is or exactly how it works but I guess it's in the gear casing attached to the electric motor. I have to say that I have never tried this on my boat but the manual says that you are then manually winding at a 1:1 ratio so when retrieving the chain, in the words of the manual 'the stress will be hard'
Apologies for the lack of visuals as I cannot get the illustrations in the Sunseeker manual to show very clearly.
However the instructions are as follows:
1. Ensure chain is locked in place using chain stopper or retaining strop.
2. Insert winch handle into centre of winch top nut and unwind in an anti-clockwise direction. Then remove top nut and washer.
3. Lift Rope Drum off the spline and put drum and top nut to one side.
4. Insert adaptor over the spline, line up lug on the bottom of the adaptor with the locating hole on the top of the gypsy and screw down using central dog on the top of the adaptor. (The adaptor has a distance piece the same length as the original drum.)
5. Use winch handle to screw down adaptor central dog.
6. Insert winch handle into adaptor BASE and rotate clockwise to draw in anchor rode.
If anyone is is Cala d'Or at any time send me a PM and and you can see the device in action.
