KevinV
Ah, okay, learn something new every dayThere is if the stop control operates a decompressor as the OP states. Not unknown on older engines; the SABB 6-8 hp for one.
There should be a screw with a lock nut on the decompressor that holds the valve down, It can be adjusted to miss when not meant to be engaged.I've heard about the fault and reckon that it's the rocker box gasket being worn, which is consequently lowering the decompression lever onto the valve stem causing a fractional but significant loss of pressure. This was the issue on my own engine, which by pure coincidence I bought from "G and that boat" a few years ago.
The fault that was described to me has exactly the same symptoms as mine had, which was cured immediately by getting a thicker/newer gasket that raised the decompression lever away from the valve.
As an interim check to see if it is the fault, the rocker box cover can be slackened off, and an attempt at starting made. It only needed my cover to be loosened, not removed to cure/locate the problem.
If it is indeed a 1GM go back to my post#9. The decompressor is not needed for starting except maybe in very cold weather to turn the engine over and build up oil pressure behind the rings and so increase compression (or rather limit the loss of compression). The recommended starting procedure is 3/4 open speed control lever to increase the amount of fuel injected on start. If the battery is strong enough to turn the engine briskly, fuel is getting to the injector and it does not start then it most likely means there is insufficient compression. These are very simple engines and just need the "big bang" to get them going. if compression is down then squirting oil in through the intake is a temporary fix, but does nothing for the underlying cause which is one of those 3 common problems in post#9 - most likely a combination for an old well used engine.Yes @jamie N that is the boat and the owner. And yes that is where the engine originated from. I suspect your diagnosis is probably right. I will pass on that suggestion.
It sounds like G did not need to change his engine a few years ago he just needed to fix the old one he had then......
G did miss the race, I was due to be his crew, and I ended up getting a ride on another boat so I did get to participate in the race.
It also needs a good battery to spin it over fast or it will never startThe three essentials are air, fuel and compression. If you've got all three it will work. It sounds like there isn't good compression - the blue fumes are unburnt diesel so fuel is getting to the injectors, and air is unlikely, but check the air filter. Is the decompression definitely off? Have you checked at the engine, not just at the control panel?
It really would help to know the make and model, as that would help people to provide engine specific diagnostics.
Probably teaching granny to suck eggs, but do remember that the spray from an injector readily penetrates skin and can result in severe dermatitis.A compression test will show if it has a valve burnt out or any other cause that reduces compression.
On this type of engine you will need to remove each injector in turn, then use adapters to fit a pressure gauge ror the reading.
While the injectors are out it would be a good idea to check the spray patern.
A DIY method is to remove one then rig it up so that you can see the tip. With a jam jar covering the injector turn the engine over and observe the pattern..
That can, to some extent, be overcome by getting the motor spinning with the decompressor engaged so there is little load on the starter motor, and then disengaging the decompressor when it's turning fast. That worked for me one time when the battery was down.It also needs a good battery to spin it over fast or it will never start
Indeed.It also needs a good battery to spin it over fast or it will never start
Could also be that the timing is well off.
Has he been fiddling with the injection pump??
