jamie N
The engine has been recently running, albeit unreliable to start. Both ProDave & I know the owner, and would probably agree that to take the engine apart to that extent wouldn't be his kind of thing.
Almost imposible to "fiddle" with the injection timing on a 1GM. It is set at the factory and the only way of changing it is to remove the pump and change the shims underneath for a different thickness. Most owners (and mechanics) would not even suss that out as the procedure is well buried in the workshop manual with a warning not to do it unless the engine is being totally stripped. I had to do it with mine because I had to refurbish the timing cover to which it is attached and damaged the shims. Fortunately was able to measure the thickness and get new ones of the correct size.That was my thought ... if injection is out of synch .... then that explains the blue 'smoke' as well.
Not all injection pumps are very complex. After looking at this video I stripped and rebuilt mine a few years ago.Good point. As far as I'm concerned, the injection pump is off limits, as it requires detailed knowledge and precision to work on it. The engineer I did my diesel course with emphasized that a) it rarely stopped engines from running and b) that working on it required specialist precision tools and a very clean environment. The major reason for it stopping engines from running was failure to observe item b!
Sounds like a fuel issue. Something somewhere is leaking air in to the fuel line. If its been happening since the last fuel filter change, fit new filters being careful to make sure they seal well. Easy to get this wrong, don't ask me how I know.Not all injection pumps are very complex. After looking at this video I stripped and rebuilt mine a few years ago.
Found it interesting and informative....
Did it on the table in the saloon.
Well an update, he finds he has water in the engine oil, so looks like proper strip down over winter. Head gasket?
