[178529]
I suppose anything that sounds too good to be true is too good to be true.I think it would need an entirely different gearbox to make it work. I'm not saying it's impossible, I just think that it would end up being much harder than you suggest. Just for starters, to get that 13HP, you're probably emitting at least that much heat equivalent - in other words, around 10kw of heat. So, you're going to need an effective blower system to keep cool air round the engine and removing hot air from the enclosed space below decks. Without it, the engine will over-heat and the below decks will become unliveable. The exhaust is dry, so it's at a very high temperature - well over 100 degrees C, probably a lot over; certainly enough to melt solder. So, the exhaust will have to be rerouted and made safe, somehow. The existing exhaust won't do - the cooling water keeps its temperature down, so it can be routed safely through lockers etc. The existing gearbox is designed for the power curve of a particular engine; it almost certainly won't be suitable for an engine which, by its nature, will have a very different power curve.
