Why not send it back?I think you've all confirmed what I suspected, which incidentally is what I have just said to Nauticalia on the phone... I think you had a dodgy batch of barometers made up!
Can you guess which ones are now going on Ebay...
I can't see how they can refuse to refund / replace
Does anyone still use inches of mercury? I thought that went out with the dinosaurs! Even millibars are deprecated; we should use Pascals. As millibars are hectoPascals (I think) there's an easy conversion.
Always been 760 mm Hg but now defined as 101325 PaIn the US is still mostly mm Hg, although the NOAA reports both side by side.
Although I find it funny that 1 standard atmosphere is not 1000 mbar.
That's because Pascals are defined in terms of more basic units (ultimately metres, kilograms and seconds), not in terms of atmospheric pressure. It's a convenient coincidence that atmospheric pressure usually falls somewhere near 1000 HPa, but it is no more by design than that atmospheric pressure is usually around 30" of mercury.In the US is still mostly mm Hg, although the NOAA reports both side by side.
All this aside, I feel like I'm going to struggle with the idea of having a barometer mounted on my bulkhead that is fundamentally incorrect - even if it technically reads accurately, it can only be accurate on one of the scales at any one time!
