Sneaky Pete
Looking for advice on which size of primary winch to use for the genoa sheets, obviously self tailing but do I use 16, 30, 40 or bigger. What do these numbers mean.
My understanding is the same as yours - but is there a standard handle length used for these calculations? Using a longer or shorter handle would change the mechanical advantage.As I understand it the number is the mechanical advantage; so with a 30 size winch 1kg force on the handle gives 30kg force in the rope. The Lewmar guide is here. My 29 footer has a 30 sq.m. genoa and the Lewmar 40s are pretty hard work at times. I wouldn't want anything smaller.
I can't understand couples who split the work that way round. SWMBO always helms and I always work the winches. This matches our relative size and strength to the tasks; of course if your relative sizes are different I'd understand. We occassionally have some "lively discussions" when she decides to put in a few short tacks and we're carrying a big genoa.Thanks very much to all who replied, I have enrolled the wife into the local gym with specific instructions to build the upper body, and I have ordered a couple of ST16's and that should do the trick..................................Well someone has to steer the boat.
There seems to be widely differing opinions on winch power. We currently have Lewmar 10s on our Griffon, with 245 sq ft genoa. They have a ratio of around 7, and are hard work on occasion. I'm pretty confident that 16s would be fine for us, but then I see others saying that I shouldn't have less than 30s.ST16s are babies. What are you sailing, a Wayfarer?![]()
Are you selling your 30s?I have downsized from a 150% genny to a 130%.This is about 315 sq ft.I still find my ST twin speed lewmar 30s hard work when it is blowing and will be upgrading to 40.2s from Harken.I do have a bad back though so have my boat set up for max efficiency.Last year I upgraded main blocks to bigger sizes with ball bearings.Much better.
