Nicholas123
N/A
Anybody know?
Anybody know?
TimIf you buy a 47kg propane bottle from Calor, it costs £69.
If you buy a 3.9 kg propane bottle from Calor, it costs £15.49
If you buy a POL to POL connector from Calor it costs £10.
Using the connector, you can refill a 3.9 kg bottle no less than TWELVE times, at a cost of £5.75 each.
It takes about 40 minutes to connect the bottles, let the gases drain from the big one to the little one, and disconnect.
If you bought 12 x 3.9kg bottles outright, it would cost you £185.88. DIY you save £106.
Assuming you are comparing refilling 3.9kg propane vs. 4.5 kg butane there is not a vast difference in price on a £ per 10,000 kcals basis
Taking Calor's refill prices and net calorific value figures from Engineering toolbox I have arrived at £3.58 / 10,000 kcals for propane and £3.30 / 10,000 kcals for butane, but please check my arithmetic.
However Calor propane I believe contains some butane. Perhaps you can find the net c.v for Calor propane and rework the cost using that.
Even allowing for the fact that Nicholas is a a self confessed cheapskate, difficult to see what difference it would make on the small volume he is likely to use in a year on his little two burner stove!
For one not Calor, i worked for them for many years and i could get it cheaper than cost price from another dealer. there are many more about if you shop around.
Tim
Just a word of caution that if you are transferring liquified petroleum gas that you must leave a small gas space in the cylinder. If you completely fill the cylinder with liquid there is a risk of bursting the cylinder and explosion.
That's a good point T, which bears repeating for anyone thinking of doing transfers. I keep a set of scales under the receiving bottle and stop the transfer at about 90% of theoretical normal load.
I gather that the risk of explosion is to do with expansion of the LPG after the end of the transfer, as the contents and tank reach equilibrium temp (there's probably a techy word that you can supply )
Anyway, a good reminder, thanks.
Surely there is another consideration here?
Butane doesn't vaporise well in cold weather so if you sail all year, bear that in mind.
If filling bottles, remember propane stores at a higher pressure.
Tony
