Which Anchor is best
imagine
23 Oct 2007
Cheshire, Holyhead
www.pch-uk.com
Hi All
I have a beneteau 473 and I am looking for a new anchor with good holding.
I have considered the Delta 30kg and the Mason suprem 27kg
Does anyone have any preference or can recommend either both are similar in price new or if anyone has a second hand one for sale.
I apprieciate all the comments
Thank you Nick
lustyd
27 Jul 2010
Hi All
Thank you Nick
Assuming you're not trying to start a big anchor thread, the Manson came out better in the YM tests than the Delta but either will work fine if they are the size specified for your boat.
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
Bear in mind that all anchor tests are a straight line increasing load. I don't trust any of the tests because at anchor the loads are angled snatch loads.
colingr
21 Sep 2007
Solent
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
FishyInverness
12 Oct 2010
Inverness
www.gaelforcegroup.com
Before the clamouring starts and every anchor under the sun is discussed, PLEASE bear in mind that the OP has put his personal consideration between the Delta and the Manson and is specifically asking about people's experiences of THOSE TWO ANCHORS!
The RNLI use Deltas - 'nuff said? Admittedly they don't anchor overnight too often!
Ex-SolentBoy
25 Nov 2006
I had a Delta. It dragged. I bought something very like a Manson. ;) it doesn't drag.
Just seen TK 's post. Yes, it is a Rocna. It works fine.
On other threads people say we should support our local chandlers. Well, one way you can do this is to buy a Rocna from them. They will then have a big order for CMP and should therefore be able to cut some sort of deals on returns. If you buy something else on principle they will have no negotiating position.
FishyInverness
12 Oct 2010
Inverness
Imagine,
So, on the evidence based so far - it seems that the experienced opinion is that Deltas drag.
Ignoring any goading about other Anchors, that leaves the Manson to discuss in order to help you with your original question....
Anyone care to assist the OP with positive/negative experience of the Manson? That way, this Anchor thread can close quickly, quietly and happily, to the relief of Many, I'm sure!
lustyd
27 Jul 2010
Ok as long as you bear in mind that ANY testing is better than hearsay and Internet forums :) it's too expensive to personally test them all and this is the best info available so I'm happy to trust it.
Chris_Robb
15 Jun 2001
Haslemere/ Leros
What complete and utter twaddle. OP for god sake don't by a Rocna - they are underspeced - designed to have a much stronger shank. As I said before - in the UK either delta of Manson, in the Med - Manson - delta not good in soft mud and will plough through mud in extremis.
lustyd
27 Jul 2010
Imagine,
All anchors will drag under some circumstances. The trick is to get one that resets well. The delta does so better than CQR and Manson better again. Unfortunately with the exception of the CQR you get what you pay for so money is often the main driver when buying.
FishyInverness
12 Oct 2010
Inverness
PLEEEASE don't let this go the way of all the other anchor threads...
The OP didn't ask about a Rocna, a Bugel, a CQR, a Fortress, a Lump of rock, a spade, a tractor axle or a Grapnel...
The OP is considering either a Delta or a Manson Supreme, and wants to know people's experiences with those anchors, can the feathers stand to be unruffled long enough so he can get an answer?
Boomshanka
18 Aug 2007
Côte d'Solent
There's only one way to find out:
[clicky]
