peter2407
Again, more of a survey thing: When would you pole out, and when wouldn't you bother even though doing so would be a benefit?
When it's not my turn to be on the helm. SWMBO won't do unlaldylike things such as standing on the coachroof holding a boathook.
Can you not hitch the boathook to the shrouds?
Yes I suppose I could drill a hole in the shaft and rig up something.
We also use the spinnaker pole to pole out the genoa, main criteria are, enough breeze to be worth sailing, and a reasonably long run to make the effort worth while. I also fit the jibe preventer in this situation.
I wouldn't bother if it was only for a mile or so.
I've just made - and tested, an aluminium jibstick and it works a treat.
I made a 2nd lightweight pole using a B&Q TV pole with poly-what-not Piston ends from Force4. I put O fittings both sides of the mast to hold the pole.
No need to drill any holes - I just had a clove hitch round the boathook and a couple of rolling hitches on the shrouds.
Beware, the boathook may not stand the pace if there's any worthwhile wind! (and how/where do you fix the inboard end?)
I tried a windsurfer mast once, and it bent double.
I just looked for TV poles on the B&Q website and pole ends on Force 4 and drew a blank on both. What length, diameter, gauge of pole do you use?
