Whats best Permateek or Flexiteek synthetic teak decking any problems encountered
Stewbabe
20 Jan 2022
Hi Guys whats the best synthetic teak decking out of Permateek and Flexiteek !! Anyone had any problems !! It would be for a 28 ft sportsboat cockpit and bathing platform !! What about warranty !! Thanks Guys
Hurricane
11 Nov 2005
Sant Carles de la Ràpita
I have Flexiteek on our bathing platform - done about 5/6 years ago.
And I've done/doing the rest with Trakmark (the trade division of Tekdek).
For me, Flexiteek has a problem in its colour fastness.
Tekdek (Trakmark) soesn't discolour over time.
This drone photo shows the difference in colour.
The Flexiteek on the bathing platform has gone a shade of pink.
Trakmark also supply for DIY
Stewbabe
20 Jan 2022
Thanks guys Permateek want £500 per square metre all in fitted !! I am going to measure but I think I need about four square metres !!
Hurricane
11 Nov 2005
Right now, I into my next phase of teak replacement (Trakmark).
This time its the cockpit.
Here is a photo of the progress so far - only just fits in my garage.
I am working on a new (to me) technique to make curved corners.
Seems to work - this is the hatch for the lazerette
Although I say it myself, I'm much better at welding than when I started. I think I've even cracked top welding!!
jfm
16 May 2001
Jersey/Antibes
I have Flexiteek on a couple of tenders and like it very much. I am a bit concerned about it going pink as per Hurricane's picture, though the tenders in my case are both stored out of the sun so should be ok.
I have had good results from Wilks Dek-King but this seems to have ended according to this post Last ever Dek-King installation?
I also have Marinedeck 2000 Stazo® marinedeck | Stazo on a tender and this gives absolutely the best grip, better than any of the others, but it's not the prettiest looking and not pretty enough imho for the mothership. Only builder I can think of using it wholesale is Amer, but imho it looks ugly on those 100 footer.
I have no experience of Permateek.
In sunny climates, eg the Med, I wouldn't use any of these products (apart from Marinedeck2000). OK on a tender, but not the mothership. I have tried it and they just feel too hot in the sun. Some manufacturers offer a version that they say doesn't get so hot, but these still get too hot imho. Perfectly fine in more northern climates eg UK
@Hurricane - huge respect and admiration for what you have done on JW!
harvey38
27 May 2008
Tek-Dek were a piece cheaper than that, our link below has quite a few photos of their work.
Hurricane
11 Nov 2005
I love challenges.
Having been retired for a long time, learning how to weld up synthetic teak is just one of the things that keeps my brain active.
Initially, my work in making the teak was average but, like most things, when you set your mind to it, you can achieve good results.
The difference between me and a professional job is that I take a lot longer over it - because I have the time.
Same with my sewing projects - a set of cockpit covers take me about a month to make and very little cost.
SWMBO lets me lay out my projects so that I can do a few hours and leave it where it is until the next day.
For example, today I only spent about 3 or 4 hours on this teak job.
Tomorrow I hope to do a bit more welding - maybe another 3 or 4 hours.
At this rate, I think it will be ready in a week or to take out to Spain at the end of March.
That said, when we did the flybridge (just SWMBO and I) it was VERY hard work.
So this time, we are making it easier and using a local one man contractor in SCM who has fitted Flexiteek several times before.
In deed he has just finished replacing a Princess 72 with Flexiteek - he stripped the old and laid the new after buying the deck from a dealer.
So, I'm making the panels and he will be fitting them.
I will post some photos of the work as it progresses.
dustywings
7 Aug 2011
Home in Lymington boat in Mylor
We had Permateek fitted to our Squadron 58 and were very pleased with it, we loved the colour and being in the UK the fact that on a sunny day it was hotter to the touch than real wood was rarely an issue (sadly!). Synthetic decks make maintenance very easy as you can just pressure wash them down when they get grubby. Real teak does have benefits of course but there is a cost differential too. You can see what mine looked like and what the process was here:
Squadron 58 Replacement Decks
Fire99
11 Oct 2001
Bangor NI
Just looked at your install pics. It looks 1st class! Great work.. :cool:
benjenbav
12 Aug 2004
I like your router jig. How did you radius the curves for the board and the perspex block?
Canopy Locked
5 Dec 2006
Nth East Scotland
I'm going with Permateak - Not brave enough to measure & fit myself - too expensive to get wrong and too visible if a mistake is made - I'm paying around £2k for 4.8m2. But that includes 2 x 400 mile round trips for the guy to come and measure and then fit on the 2nd visit. I think it will be well worthwhile!
Hurricane
11 Nov 2005
My progress today.
Doesn't look much further on - I had some interruptions today.
But I did manage to do the borders around the hatches today.
Ready for a measurement check tomorrow - then the bit under the cockpit table and then the border down to the transom gates.
Hurricane
11 Nov 2005
No set jig.
I have spent a lot of time thinking about borders - even some hairbrained ideas of CNC routing!!
The solution in the end is quite simple.
I cut two perspex discs - exactly 57.25mm radius
I fitted on onto a cheap Palm Router, making sure that the disc was centered.
The other disc has a hole in the center for a pencil.
The process is as follows:-
Draw the profile of one of the edges (I used an old school compass for the round corners).
If it is an inside border/curve, I draw the profile for the outside edge (in this case using a compass)
If it is an outside border/curve, I draw the profile for the inside edge (in this case using a compass)
I hope that makes sense.
After cutting the appropriate edge, I use one of those bendy French curves.
I push the French curve around the previously cut edge and hold it in place with some weights (a good set of weights are vital when making this stuff).
I then use the disc wit a hole in the center to draw the other edge.
And cut it.
That now leaves a border piece that is the exact size.
This pic shows the technique - in the pic, I've already cut the curve.
I then glue that border piece into the job.
The reason for all this is that later when the that piece is fitted into the job, I can use the same edge and same French Curve but this time I use the disc that it fitted to the Palm Router.
Like this
This leaves a nice groove with smooth edges like this
Those straight grooves are made using a standard Plunge Router and a perspex fence.
Trakmark supply a special soft welding rod with a lower melting point for top welds.
Using the same weld tool and nozzle, the weld rod is fed into the groove.
Excess rod is cut off and the job sanded.
Final result
Hope that answers the question.
benjenbav
12 Aug 2004
No set jig.
And cut it.
Like this
Final result
Thanks. All good thinking …and execution. 👍
Stewbabe
20 Jan 2022
Hi which company are you using and where is your boat! Does that price include preparing the floor/removing old teak! Thanks Stew
