Actually, IIRC, testing the flow is in the Tides manual.i think through my own experiece its very important to check the water flow feed pipes ,if mine had been checked the second failure would have been avoided .
Just looking at Nito's image back in #69 - just looks like the two mating faces are not sitting square, slightly skew, I am sure mine sat square....
Interesting report though, food for thought...
Also why is a jubilee clip attached to rotating shaft, is that normal, surely it would create an imbalance?
you're joking, come and pull mine (45mm shafts) no fking way unless you do one finger pushups for fun (saw a scary clip on twitter last week I think)!
I'd hazzard a guess that ss rings and clips have slipped.
For good measure, I've marked with a permanent marker the point where the ring should be according to specs. Will be a good reference point down the line. If the blue line disappears, means the thing slipped.
I don't think there's a "normal" setup, so only Sunseeker or someone familiar with your particular boat model can answer your question.Mine is a Sunseeker Portofino 400, I know there are cutlass bearings in the P brackets, but I don't know if there is any kind of seal/cutlass in the stern tube/shaft log, does anyone know if there normally would be?
FWIW, I'm aware of three possibilities:
- just ONE cutlass bearing on each shaft (on the P bracket, obviously);
- TWO of them, the second being somewhere along the thru-hull tube, on the external side of the seal;
- THREE of them, where there is a long(ish) thru-hull tube, with one at each end, both on the external side of the seal anyway.
Apropos, you said "any kind of seal/cutlass", but all the cutlass bearings that I came across (regardless of their number) are only meant to avoid shaft vibration and/or whiplash effect, but with no sealing function of any kind.
Not saying that there isn't some kind of cutlass bearing that also holds water pressure, but pretty sure I've never seen one - and neither heard of it.
That is indeed VERY scary.
I'm sure others on here will disagree with me but now that you have said that, if I were you, I would change them for Tides seals.
You would have an issue though - there isn't much space to get any seal in there.
Especially if you wanted a spare Tides style replacement seal on the shaft.
I think I would explore the option though.
Just the thought of getting on board one day, starting up and shredding the bellows, scares the living daylights out of me.
Who checks their glands after starting and moving off!!
when i arrived in Opesa from Majorca as soon as we come off the plane after a very short time the bilge pumps started working so as soon as i was tied up i went in the engine rom and you could hear gallons of water entering the boat.
the shaft seal was completely destroyed and the feed pipes both ripped off,
i undone the clips on the bellows ,slid it up the shaft and forced rags in-between the shaft and stern tube which eventually stopped the flow.
the whole seal,housing bellows and clips lasted about eight hours before completely melting though lack of coolant water.
the feed pipe from the engine was partially blocked causing this to happen again so although t.c did the repair what they didn't do was find out why it failed . i contacted tidal seals and thats who told me it needed eleven litres a minute to keep it cool.
i passed this information on to TC they then checked it and replaced the restricted feed pipe
It sounds like you know what you're going to do, if I were you, I would bite the bullet remove the old PSS clean everything up, fit new PSS, check flow rates and play in cutlass bearing and replace only if necessary, load up the beer fridge and enjoy the rest of the season there will be more problems to resolve shortly, there always is...!
Best of luck sorting this out....
Nito, your bellow does look too compressed just by the look of it.
