MapisM
Are you sure to be looking at the same area I was referring to?Sticking up , it’s just salt
This border doesn't look covered with sticking salt to me.
I'm not positive that it's pitted, though. I did ask for a better pic...
no orientation P, either way is OK, rotor is symmetrical no marks anywhere.I don't know PSS seals well enough, doesn't the rotor have a specific orientation for some reason?
If not, your suggestion makes good sense of course.
But if that's indeed pitting, it remains something that shouldn't have happened.
Worth checking the shaft earthing, methink...
There are stories of boats unused for months, where the stator and disc bond together. The friction means that when the prop turns, if they are stuck together, the bellow can shear/split as it will try and turn with the disc.
Nito, out of curiosity, did you pull the bellows from the ss ring using your bare hands?When you separate the carbon stator from the SS disc, the rate of water that enters is quite alarming! I don't know how to upload vids yet but here is a still of the water coming in which doesn't capture the full force of it!
The way I see it, sticking a flat head screwdriver in between is a definite NO NO.
Judging the trouble I had preloading them to 25mm as per the instructions I really cannot see how you can pull the carbon bit back without any tools.
so, I'm either way too weak and need to go to the gym, or ss ring has slipped back and prestress load is minimal (hence the leak!)
cheers
V.
Be useful to know the source of the 'stories' I have not heard of them but not suggesting for one moment they do not exist, just would like to know the circumstances.
My old F43 had been left for many months unused when I bought her and straight off on a 500nm trip. I never had any issues with the PSS seals, had one of the lip seals go on my P45, hence replacing them. I would like to know, I would have considered PSS if ever I needed to replace later as I do like the principle.
you're joking, come and pull mine (45mm shafts) no fking way unless you do one finger pushups for fun (saw a scary clip on twitter last week I think)!Using my super strength alone! I wouldn't dream of prising something against the sealing surfaces. Pulling it back slightly for water to escape wasn't overly difficult....
That is indeed VERY scary.There are stories of boats unused for months, where the stator and disc bond together. The friction means that when the prop turns, if they are stuck together, the bellow can shear/split as it will try and turn with the disc. That's a scary thought and having seen how quickly water enters I'm fairly sure that could lead to a catastrophic event. PSS says to seperate the stator from the SS disc on a sitting boat before starting up, I can totally see why, though I suspect it would take a matter of months for this to be an issue and I expect the bellows would also need to be past their best for this to occur.
Ohhhwhen i arrived in Opesa from Majorca as soon as we come off the plane after a very short time the bilge pumps started working so as soon as i was tied up i went in the engine rom and you could hear gallons of water entering the boat.
the shaft seal was completely destroyed and the feed pipes both ripped off,
i undone the clips on the bellows ,slid it up the shaft and forced rags in-between the shaft and stern tube which eventually stopped the flow.
the whole seal,housing bellows and clips lasted about eight hours before completely melting though lack of coolant water.
the feed pipe from the engine was partially blocked causing this to happen again so although t.c did the repair what they didn't do was find out why it failed . i contacted tidal seals and thats who told me it needed eleven litres a minute to keep it cool.
i passed this information on to TC they then checked it and replaced the restricted feed pipe
i think through my own experiece its very important to check the water flow feed pipes ,if mine had been checked the second failure would have been avoided .Ohhh
I was going to get TC to replace my starboard one - the one that had a failed/replaced lipseal.
TC replaced the port seal when they moved the engine for me to get access to the front.
Incidentally, we replaced it because the blue bellows were showing signs of wear.
So, I was going to replace the starboard one but now you have got me thinking - if it isn't broke - maybe I shouldn't fix it - I still have a spare lipseal on that shaft (Princess install two spares on each shaft).
