PaulRainbow
>but in the case of very small leaks that allow air into the system it doesn't always work.
Any leak will show on the kitchen roll even a small one. The symptom of an air in the engine is it runs then the revs drop quickly and it cuts out.
Still not got the hang of the quoting i see
Small air leaks in the suction side of the fuel system will not necessarily leak diesel, therefore the paper towel method you describe will be less than helpful.
Symptoms of air in the fuel system will vary, anything from plain non-starting to a minor misfire. Depends on a number of factors, where the leak is, how bad it is, the engine, engine speed, engine load etc.
None of the symptoms of air in the fuel match the description given by the OP.
