Mandarin331
Looking at a gas locker vented via a hose leading from the bottom of a gas tight locker to a skin fitting. Can anyone tell me What should the internal diameter of the hose / skin fitting be as a minimum?
Whatever you use, it needs to drain freely.Hi, I had a query on this too.
Is hose ok for the (unpressured) drain? Due to the shape of my boat fixed pipes would be awkward.
Also, what fitting are you using at the locker?
Best practice
We recommend you to fit, whenever possible, drain hose that
complies with a recognised standard such as ISO 7840 for fire
resistance or BS 3212 for LPG.
