Bru
Doxford P Engine cos my old man was involved in testing the prototype ;-)
Most gen sets run at 1500 (although a few at 1800 ) to suit alternators
Northern lights use the same base unit as volvo Perkins as above
My 1980 Universal 5424 continues to run sweetly and start first time after prolonged (up to 1 year, often 6 months)periods of non use. It has to put up with sub zero winters and hot (100 F) humid summers. The only attention it gets is an annual service and filter change. I believe Universal is the USA name for Kubota.
Not as good as Nanni made them
Lister Blackstone ERD took some beating these were on the old Lymington/Yarmouth Ferries, far better than Polar and Gardners are excellent.
Back to smaller engines - Ronhilda still has the original 1987 Ford 1.6 416 XLD fitted. Ultra reliable and economical. I am now onto my third timing belt. Yachts around me using Volvos Betas etc seem to have to replace their engines every 10 years or so.
Brian
No anodes in mine,due to similar metals being used. each H/E is made for one engine only & not 3 or 4 sizes, so no over heating or blocked tubes due to the anode wasting.Hi sailorman,
I don't want to start a pi$$ing match between Nanni and Beta owners.
But can you tell us why you think Nanni is better?
Marine engines in yachts are obviously the ones with the flywheels on the front, Buhk Volvo md7's etc. However the best marinised engines and the best thing that ever came out of Britain is the Gardner LW series diesels. Started life in about 1928 as an army truck engine, powered your double decker buses. My old fishing boats engine is over 60 years old and still all original and still runs perfectly. New owners for her now though I have retired.
The marination is generally better & Nanni are recognised by Kubota ( i dont think Beta are ).
One down side of my Nanni is the alternator belt dust issue & the belt tensioning device is not workman like, it needs a mechanical screw tensioner. The newer engines have the poly vee option
Over the years sailors have tried to marinise almost every type of engine. Some are total dogs ears, some are ok but is there any that really stand out. what in your opinion is the best marine engine made for a sailboat and why?
Any freshwater cooled diesel that gets run regularly under plenty of load and it's oil changed regularly. That said I have never met an owner of a Mercedes OM diesel that does not love it, though it is a marinised German taxi engine.
"The Kubota base engines are great though"; not in my case! The Chysler Crown which served in my boat 1951-1991 was replaced by a 1.5 BMC, cost £300 supplied and fitted. After 12 years this was replaced by a 5cyl Nanni 62hp costing about 10k supplied and fitted - the front piston came adrift after 5.5 years making it an uneconomic repair. It was the Kubota rather than the Nanni marinisation which failed, but the suppliers were totally disinterested.
R U sure that was a Kubota based Nanni engine"The Kubota base engines are great though"; not in my case! The Chysler Crown which served in my boat 1951-1991 was replaced by a 1.5 BMC, cost £300 supplied and fitted. After 12 years this was replaced by a 5cyl Nanni 62hp costing about 10k supplied and fitted - the front piston came adrift after 5.5 years making it an uneconomic repair. It was the Kubota rather than the Nanni marinisation which failed, but the suppliers were totally disinterested.
