What is a Ramp gear inside a windlass gearbox
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I am having problems with my windlass. Lewmar says that it may be the ramp gear sticking
I quote....
you have a ram gear set up in the gearbox that allows you to manually turn the gypsy to pull your chain in. what can happen is a build-up of friction that means the resistance is enough to allow the ramp gears to slid over each other. This can normally be fixed with a strip down and clean and maybe a little rub down of the solid bearing in the base of the unit.
What is a ram gear or is it ramp gear? What does it look like and/or how does it work???
Google is not much help
TudorSailor
My guess is its a pawl and ratchet gear which is part of some Lewmar gearboxes and would allow you to wind in the chain by hand and will cause problems if the pawls get stuck engaged or disengaged due to friction which can be fixed by cleaning.
See around parts 8 and 9, and 12 and 13
Spring-loaded pawls are definitely a feature of winches but I'm not familiar with pawls in windlasses, although mine does have a manual lock which operates a bit like a pawl.
Richard
Just heard from Lewmar. They say it is a gear inside of the gearbox that has a ramp on one side , so in one direction it drives, and in the other it slides up the ramp, its part of the manual recovery system inside the gearbox.
I guess I will have to open the gearbox and see what I find! Best done at the end of a trip and not the beginning
TS
My old windlass has an arrangement like this would seem to be. It's a shaft bearing that looks like a needle roller but the cage, instead of having two square faces, has one square and one tapered (ramp). In one direction it acts as a bearing but in the other the needles roll up the ramps and lock the shaft.
That sound like a device commonly called a roller clutch.
Also known as a 'roller clutch or freewheel'?
