Wansworth
Whathappened to buyinga bare hull and fitting it out?
It turned out to be more expensive than buying a complete boat!Whathappened to buyinga bare hull and fitting it out?
….. which also turns out more costly than buying a boat that had not been wreckedThey’re all in the hurricane fields rebuilding posh, coded boats
... and that's without costing their time, but it's OK 'cos they're going to make millions as Youtube stars.….. which also turns out more costly than buying a boat that had not been wrecked
Fame, fortune and floating fornication... and that's without costing their time, but it's OK 'cos they're going to make millions as Youtube stars.
Where can I sign up ?Fame, fortune and floating fornication
Don’t think my father was thinking about sex fitting out his freeward 30,but then Icouldbe wrong!Where can I sign up ?![]()
Do you remember the ferro-cement boat craze? When people thought they could get a big boat for a lot less than one built of wood but failed to appreciate the high cost of fitting out a large boat.For every one completed to a reasonable standard there will be a couple of dogs, a couple that change hands and more that just sit there gently rotting away. There is a good example on the forums of someones expectations and vision exceeding his time or desire but not his ability because he seemed very competent if a little ambitious.
I think that's the nub of it. An amateur is unlikely to have all the skills to finish a boat to a good quality. To produce an interior fit to the same quality as a boatbuilder requires cabinet-maker skills. Rigging a boat requires another set of skills, engine installation another, electrical work another and so it goes on. Most of us can manage to maintain all these things, but starting from scratch is a different kettle of fish. A boatbuilder will have specialist workers in all these fields; how can a lone amateur hope to match the skills? It's amazing that some do!For every one completed to a reasonable standard there will be a couple of dogs, a couple that change hands and more that just sit there gently rotting away. There is a good example on the forums of someones expectations and vision exceeding his time or desire but not his ability because he seemed very competent if a little ambitious.
Coincidentally I saw a very pretty small schooner in Canna last week that turned out to be a ferro cement Endurance 40. From a distance looked in very good condition.Do you remember the ferro-cement boat craze? When people thought they could get a big boat for a lot less than one built of wood but failed to appreciate the high cost of fitting out a large boat.
I think there are some people who simply like doing shore based projects, like building a boat. That is their hobby, not sailing or voyaging. And that is fine. Even if they finally finish and launch the boat, many of them sell soon after rather than actually use the boat.But cost in the happy hours making your yacht?
