Centurion06
Hello - I have noticed this type of nomenclature appearing in boat reviews recently I don't understand it can anybody explain for me please
I wouldnt know. Im a gentleman and dont bother with all this tacking malarky.Can I ask a question ?
How many here have a boat that can tack 70 - 80 deg (ie 35 - 40 deg either side of wind ) ? That's pretty good angle ... and most boats I know would be hard pushed to maintain a good speed with such angle ... with most sitting in the 90 - 100 deg or more.
No doubt I am now going to shot at dawn for this .....
Yes. 70-80 degree tack as an angle over ground (COG) is bullshit.Can I ask a question ?
It may well be a reference (as I noted) to heading rather than track - and yes there are some boats hat can achieve 80 degrees but unlikely with "normal" cruising boats.Can I ask a question ?
It depends on the type of boat / rig - and where the jib sheets go gives a clue:Can I ask a question ?
Learn to tack sweetly & you would not need the winch handle.I have no idea what mine is.
I am usually too busy trying to find the winch handle and kicking the crew out of the way to be looking at compasses
Depends on the boat. With a fairly narrowly-stayed mast and forward inners for the 110% jib to get round, our tacking is seldom of the tidiest. In flat water and the right amount of wind we can do it well enough, but in a seaway the idea of getting the jib tight enough by hand is optimistic at best.Learn to tack sweetly & you would not need the winch handle.
Yes! but you are the sort of bloke who thinks that a Rocna is as good as a fishermans.I believe that an Anderson 22 is a true 70-80 yacht.
And it's 70 - 80 with a small superscripted o afterwards to indicate degrees.
This I think is what makes the difference. My boat has a second set of genoa car tracks on coachroof for use with the working jib. With the 135 genoa on, part furled or not, I lose a few degrees.- 3D laminate blade jib with sheet tracks, or more likely low friction rings plus inhaulers, on coachroof very close to centreline, yes very feasible..
