Sixpence
All plans for this weekend have gone up the spout for one reason or another so I end up with the unenviable repairs to a steel framed pool . I left it empty overnight for one night during the winter and we just happened to get hit by a storm that night which bent a load of the T piece legs . Where the upright meats the T piece some of the welds have split so although I've managed to straighten them all out , I need to weld the joins again , and also reinforce the others.
So I had a go with a stick welder but the only rods I have need a fairly hefty current to work properly which blasted holes in the first attempt so I switched to the Tig welder ( could be Mig but I think it's Tig ) . With the power set to minimum there were some joints where the thing still blasted a hole and others where it had almost no effect at all so I ended up constantly changing settings to get it to work .
I've finally got all the legs repaired , and ground to a half decent finish but , here comes the question .
Is there any way I can tell if the weld has actually worked , short of putting them through the storm test again . Also , if anyone has any tips on welding they would come in useful to me as you've probably guessed that I'm a total amateur when it comes to sticking bits of metal together .
