Welding for beginners
cliff
15 Apr 2004
various
Thank you very much for that William , I must admit I didn't know there were so many different ways and your post confirms that I used a MIG setup
[/ QUOTE ]Did you use MIG or MAG? There is a difference......
Most cheap and nasty DIY GMAW machines are MAG - that is they use an "Active" gas such as CO2 and are a real PITA to set up and use efficiently on thin sections.
Try running a bead on some thin sheet metal first setting the feed speed/amps to give a stable arc then change your travel speed to see the difference in bead appearance - too slow and you will have burn through, too fast you will have a raised bead (possibly intermittent). You can also adjust the stick-out length (the amount of wire sticking out between the tip and the work piece) and see the effect that has. With practice you will find the "correct" mix. BTW too much gas (too high a flow rate) is as bad as not enough due to turbulence in the shielding gas and induced O2.
Ever considered taking a night school course in welding? /forums/images/graemlins/ooo.gif
If that does not appeal have a look HERE /forums/images/graemlins/grin.gif
or even HERE /forums/images/graemlins/blush.gif
or if you are really keen HERE /forums/images/graemlins/shocked.gif
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
Avocet
3 Jun 2001
Cumbria
I find CO2 is often a bit better on very thin mild steel sections - it seems to cool the metal a bit better than argon.
Lakesailor
15 Feb 2005
Near Here
The mixed bottles seem to work better for me. I do agree with Cliff though. My stick welder is a Clarks air-cooled device and it's a pig to use. I used to have an Oxford oil-cooled welder and it was easy peasy. I may even change back.
cliff
15 Apr 2004
various
[/ QUOTE ]CO2 increases penetration so perhaps you have too high a flow rate which is giving additional cooling however the numbers (thermo-dynamics) don't add up.
Sixpence
24 Aug 2005
Here, yah fule
Cliff , I may be wrong but I seem to recall that welding and weld inspections are your speciality , isn't it what you earn a crust doing as a career ?
cliff
15 Apr 2004
various
Guilty as charged, M'lud. Only a couple of my "talents" though. Metallurgy is my field and that takes in a multitude of sins. /forums/images/graemlins/grin.gif
Sixpence
24 Aug 2005
Here, yah fule
As I thought good buddy , thanks for the e mail , I'll listen to an expert every time /forums/images/graemlins/wink.gif , no offence to anyone else that helped but if there is someone here that does it for a living , well , it's like when I have a plumbing problem I know that the headmistress is who to call on . Thankfully , when the eggspurts aren't around , others offer thier help , much appreciated everyone
Sixpence
24 Aug 2005
Here, yah fule
Just to update and clarify , I understand that WilliamH is pretty well qualified in this field , as are others , so not intended to pick on Cliff as the expert alone , I do know there are others , and thier help is also appreciated
