Weed round anchor chain
johnalison
14 Feb 2007
Essex
I have had anchor chain weeded up so much that I couldn't raise it after an overnight stay. It doesn't take a very big ball of weed the contain so much water that it amounts to a good part of a ton. I think the only solution was to just pull bits off with a boat hook. I have never marked with cable ties.
TSB240
17 Feb 2010
Don't know how you reduce it?
I carry a £2.99 Lidl folding saw knife ready for cutting lines. It has a 250mm long saw blade and is much sharper than a bread knife.
Never had to cut a line yet but had to cut a huge ball of seaweed off our anchor chain in Old Grimsby sound with it gaffer taped to a boat hook.
Friends on anchor in same place had to get a diver out a day later to cut a similar ball off their prop.
Diver cost 100 times more than Lidl Saw knife.
I don't think they were down tide of us when I cut the weed free ?.
LONG_KEELER
21 Jul 2009
East Coast
I'm seriously thinking of buying a quality trigger fingered litter grabber. Not only for anchor chain but for the prop too. I was down to 1.5 knots coming into Brightlingsea this year after a grand sail with the prop spinning. I cannot prove it but I'm sure you collect more weed with it spinning under sail.
Neeves
20 Nov 2011
Sydney, Australia.
More seriously
Don't anchor in weed.
It would be tedious to repeat, but I will, the reasoning and you are all intelligent and caring individuals - and as such - it is difficult to understand why the question was asked at all......:)
Sea weed is currently a common item in Japanese cuisine, it is used as a fertiliser and was (still is?) a source of iodine and much, much more (cosmetics, gum - not forgetting being the nursery for the ocean's inhabitants).
We worry about plastics in oceans (and paint on our chain) but anchor in weed beds - anchoring - compromises, compromises
Jonathan
sailaboutvic
26 Jan 2004
Northern Europe
More seriously
Jonathan
Jonathan I can tell you being back in Northern Europe water there no telling what your anchoring in .
Press the down button and hope for the best . :)
NormanS
10 Nov 2008
Or you can be sensible and install and use a fishfinder. That will clearly show the state of the seabed, where you propose to anchor. I know lots of anchorages which are notorious for poor holding in weed, but there are still clear patches, easily found with a fishfinder.
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
A lot, lot worse than weed: after filming this, the following day it was my boat with a giant load of floating vegetation a couple of meter deep pushing on the chain, the bow pointing very seriously down and the stern up. Excellent anchor test though, I don't think the boat could pull more than that, like holding a truck at 90° with several knots of current :(
The weaponry I used
LONG_KEELER
21 Jul 2009
East Coast
More seriously
Jonathan
As usual, you don't know what you are talking about. :)
The question has nothing to do about anchoring in weed.
This is weed , primarily produced in the UK Summertime and floats on or near the surface and is moved almost constantly by wind and tide.
ctva
8 Apr 2007
I use a sharpened bill hook (from Machine Mart) attached to an old boat hook pole. This hooks and cuts the weed so it falls off very quickly from the accumulated ball on the anchor. No pics unfortunately.
Neeves
20 Nov 2011
Sydney, Australia.
If you want to have an international community you might need to be a bit more descriptive of your issues.
It must be great to be so understanding
I take exception to the criticism when the OP contributed to the error - pot calling kettle black (or some such) comes to mind. I think there would be less misunderstanding if you actually posted your threads with sufficient detail to allow focussed answers. I note that along with me, not knowing what I am talking about, there is NormanS, who is guilty of the same misinterpretation. Maybe if you seriously want help you could extend your use of the English language. :)
Jonathan
Mudisox
4 Jan 2004
Dartmouth
Cut it off as it reaches the bow fitting, bread knife with serrated edge is good for me. This season I noticed an awful lot of it the other side of the channel floating on the surface which also collected on the prop.
rib
29 Jun 2004
west country uk
You can actually eat quite a few different sea weeds. I went on a seaweed foraging course.. Years ago.. Some taste like garlic and pepper. Bacon. Pasta. Some boiled. Some dryed. Some straight as.. Can't remember much now but I do remember it must be picked not collected while floating. And not near a waste/storm pipe. Lol
Draystone
17 May 2022
Had the same problem in Old Grimsby Sound. I used an old tree pruning saw attached to the boat hook. It didn't work well. The blade is too flexible. I like the bill hook idea.
Anchor was in sand, floating weed. I think it maybe called shoestring weed. Thin in 4m lengths, tough and slimy. Enough of it on the chain to stall the windlass when trying to lift above sea level.
LONG_KEELER
21 Jul 2009
East Coast
(y)
It's not uncommon to see boats reversing into the tide after getting up the anchor on the East Coast. I try to remember to do it but invariably forget.
