Richard10002
My memory of these things is from removing the fitting to replace it with a blank, in order to avoid damage when lifting.
I’d guess it was a Raymarine fitting, and screwed in, perhaps with a big “O” ring/gasket, rather than being sealed with sealant.
The first time I did it, I was worried about the boat getting flooded. However, with the blank and a bung handy, the water didn’t come in too fast, and it was easy to screw the blank on, or in, (can’t remember over a decade ago).
So I am wondering if there is a way of removing it and fitting a blank, or a bung, thus stopping the leak in the short term.
With hindsight the above wasn’t particularly helpful.
I think I would do what you are planning and, having looked at your picture several times, it does look like it’s a case of failed sealant, where your CT1 would sort it out, even a normal thin bead, as against a big glob. So I would probably squeeze a bead of CT1 in order to stop the inch a day, or whatever it is.
No doubt you will have a plan for the unlikely event of catastrophic failure, something that should never be too far from the forefront of your mind, even when a boat is functioning perfectly.
