NickWilson1972
New Member
Many thanks for your reply.If the pump won't prime after a (typically) brisk sail and you don't have a blockage then you either have an airleak (strainer lid, jubilee clips, raw water pump) or the pump is worn and has lost some of its suck. If you fill the pipework manually by topping up the strainer it will probably work (I'm assuming you hadn't drained the pump when on the hard which is why it was working before) but when sailing quickly the venturi effect can pull air into the system and if the pump is worn and/or you have an airleak it will no longer prime. Often this is because the inside of the cover plate has worn in which case you may be able to simply reverse it provided its flat and not stamped with the part number etc. Alternatively you can buy one as part of a refurb kit. A worn seal and/or shaft in the pump can also allow air in or the body of the pump can wear. The former are easy to repair and the latter probably means a new pump. Other reasons for a raw water pump not working include a blocked heat exchanger / exhaust elbow or a failed impeller where the rubber has separated from the central boss but this sounds unlikely in your case.
I hope that helps. I did have a quick look for a YouTube video but you may have better luck if you search the manufacturer. If the cover plate has 3 screws I think its a Jabsco. If it has 6 it should be a Johnson and if you can identify the relevant rebuild kit it's not complicated even without a video.
I know there are no blockages as in the post mortem I managed pour water in at various points and watch it flow out at various points so I know the whole system from intake to exhaust outlet is clear enough for water under gravity to flow
Air leak sounds like a possibility. I hope its that rather than a pump rebuild which is well outside my field of experience
The cover plate has 6 screws so thanks for the tip its a Johnson
This would appear to be the appropriate rebuild kit
Beta 10, 13.5, 14hp Water Pump Rebuild (6 hole) Kit - D
