WATER pour down inside of mast, any cures.???
Phoenix of Hamble
28 Aug 2003
East Coast
mishapsandmemories.blogspot.com
Your mast should have a bung inside?... and a drain hole drilled just above the bung at deck level?
Most likely is the drain hole blocked.... have you checked?
Also, does it have dedicated wiring channels?.... these should also be sealed if not in use, or capped at the top.......
Redmond
29 Oct 2003
London
It floods down mine - but we just live with it and it doesnt do any harm. I wouldnt like to have it pool inside the mast though and draining into the bilg seems the best option.
Red
Phoenix of Hamble
28 Aug 2003
East Coast
It shouldn't pool in the mast...the bung should stop it at deck level, and it should drain away harmlessly from there thrugh a drain hole..... wouldn't want my bilges filling up every time it rained!.... I'm trying to get a dry boat...... otherwise eveything will be permanently damp all winter....
PS the bung is usually a big piece of shaped closed cell foam..... next time you get your mast dropped, speak to a rigger... they'll be able to source one for you of the correct shape, and then its easy to fit....
pandos
15 Oct 2004
Ireland, (Crosshaven)
There are dedicated wiring chanels and some loose cables. Last night in a bout an hour I filled a mug with rainwater that ran down one cable. I have no intentions of having the mast dropped. I have thought about injecting foam into a baloon to form a barrier.
doug748
1 Oct 2002
UK. South West.
I agree with Redmond, I dont find it much of a problem.
However.....I do intend to split my raw water engine intake to drain the bilge water through the engine before shutting down. Thus giving the engine internals a nice freshwater rinse! Brian.
