Temeraire
Hi,
I hope someone here can help. We had a new Hanse delivered last Nov, & so far the Volvo 2020 engine has only seen about 20hrs use. I've been away working for the last two months, & went down yesterday to find that the sump below the engine was full of water.
I was just down getting ready for our first longer passages i.e. longer than day sailing, & was just charging the batteries while the boat was in its berth. Starting to go through where everything is engine wise & noticed the sump was full of water.
I cleaned it all out dry this morning & gave the boat a run up & down the river for 1-2 hrs, while keeping a close eye on it, & noticed the water coming very slowly from the overflow pipe from the Vacuum Valve. I say slowly, but after 1-2 hrs we've got an inch of water in the sump again. Is this normal, we had a 25fter with a volvo 2010 & never had this problem.
The engine is (should be) warrantied, but I would be grateful if anyone could shed any light on why this may be happening, before I make a tit of myself with the agent. I have to be honest that I'm not really sure how the vacuum valve really works.
All the stop cocks are open, there's cooling water coming out of the exhaust, & the engine seems to be running fine.
the book says ' a correctly mounted vacuum valve prevents the occurance of a siphoning action with the resulting penetration of water into the engine.'
Its on the seawater cooling side. So I read this to be that it stops any siphoning of water back into the engine via the exhaust while sailing.
PS. Its the first time the engine has been run since Jan.
Any assistance would be very much appreciated.
I've had a look through the search function, & can't find a similar problem listed
Matt
Matt
