Pyramid
The filler cap neck, to which you affix the filler cap, pressure release cap, has coroded at the weld - I use that word loosely and now the whole neck is on the move. Clearly this means cooling fluid escapes from the fracture rather than via the filler cap working as it should when the pressure increases and the escape tube. So, as it stands any pressure usually expected within the heat exchanger is released immediately via the fracture.
Now VP say that this is not a repair they undertake and it would mean a new heat exchanger! And for obvious reasons, I don't want to go that route.
But it was suggested that the use of a two part epoxy type - good as metal - material applied carefully should suffice, at least until the engine or heat exchanger does finally give up.
Incidentally the engine continues to run like a dream. But should any pressure build then it needs to be released properly with any resultant coolant ending up in my empty Special R plastic bottle, as it always has. It's never very much and once ejected with the engine findings its natural level, all's well with no overheating issues.
VP that it won't hurt the engine, but, in view of the fact that the engine is equipped with a pressure release cap then clearly I need to do something?
Any recommendations re a suitable two part metal type material.
Si.
Si.
