BabaYaga
I didn't like the requirement on the Beta to check the Anode regularly (Beta say a 6 months check may be necessary) and remove and clean the heat exchanger annually.
It should be noted that the heat exchanger design was changed a few years ago. The anode now sits in the water stream exiting the tube stack, which I believe should limit the amount of crud blocking the lower tubes.
On my 20hp Beta (from 2006) I only take the tube stack out for cleaning every second year, which is fine with less than 50 engine hours/year. Anode is changed every year though.
