superheat6k
I never realised these were that clever. One to bear in mind next time my engines won't start though !These are insulated return to - all the switching is done internally. For the two wire version, the wires are simply + and -. Apply 12v to the positive and it energises the pull in coil. At the top of its stroke, the plunger hits a changeover switch which cuts power to the pull in and applies power to the hold in.
The later solid state three wire version still does all the switching internally, but needs an additional permanent 12v feed for some reason. So you have permanent +, switched + and - wires. Needs the extra permanent 12v wire adding if using this version on an older engine built with the two wire version.
Sorry if I'm not explaining this too well, it makes sense when you take one apart
And I'm too embarrassed to mention the time I'd left my lower helm keys in the stop position overnight and couldn't work out why the engines wouldn't start from the upper helm the next day. I'd got as far as stripping fuel filters before I accidentally touched one of the stop solenoids to find it warm.......
Happy New Year to all on here - the new season is coming to a Marina / Boatyard / River / etc near you !
